PIX 515E with Failover...failing!
Aug 03, 2006 1 Replies
My scenario:
2x PIX 515E ver.7.2.1 with failover active-active
The problem; every 3 to 5 hours (more or less) the active PIX fails....and the other takes control.
This is something continuos; after X hours the active one fails and the other takes controls; I can see the fail with the sh failover command but cannot see why its failing.
any idea to check why my PIX are failing?
thank you
I have no idea why your PIX are failing, but syslog is your key to understanding. Set up a syslog server and configure your PIX to tell you why they think they are failing. Once you know that, you can try to determine what is actually wrong.
Good luck and good hunting!
