setting up site-2-site with PIX 506e VPN Wizard
Feb 16, 2007 3 Replies
Jump to replies (3)
Hi All: looking for an introduction on setting up a site-to-site vpn between two PIX 506e using the wizard.
Pix 1 has inside IF 192.168.0/24 Pix 2 has inside IF 192.168.1/24
I want to enable 192.168.0.10 to connect to 192.168.1.15
I tried to step through the wizard, but am stuck at what to configure for the remote IPSec Traffic Selector.
If I select the inside IF of PIX 2 and enter 192.168.1.15 as the termination point, I'm prompted to provide a static route. Am I setting it up correctly up to that point? If so, what IP/IF would I want to specify for the route?
TIA
I could suggest you to set up a real LAN to LAN VPN based on IP traffic between
192.168.0.0/24 and 192.168.1.0/24. Then you can manage which kind of traffic allow on the tunnel using traditional ACL list applied on incoming interface (usually "inside") from the starting device.
This way you don't have to re-build the tunnel each time you need more traffic to pass through it but just to adjust the filtering ACL (not that defines the interesting traffic of the VPN or better the encrypted one)
HTH Alex
Thanks, but I'm not sure I understand how a "lan-to-lan" VPN differs from what I'm doing? I barely grok the VPN Wizard as it is .
I also don't understand "rebuilding the tunnel each time you need more traffic to pass through"...is the site-to-site VPN restricted in some way?
Allow me to clarify that this is to allow periodic connections between two SQL Servers, although the actual data being transfered is quite modest.
PIX 1 is on a 10-Mbit line, and PIX 2 is on a 3-Mbit static DSL connection.
Thanks again for your help!
I understand what you're saying, but I still am not clear on the initial configuration of the remote site in the wizard.
I add 192.168.0/24 for the local site (PIX 1), but which IF and IP address do I specify for the remote site (PIX 2)?
192.168.1/24 and the inside IF? or the public IP and outside IF?
