Pix 506E IPsec site to site VPN Problem
Aug 02, 2005 4 Replies
Jump to replies (4)
Hello All,
I am trying to set up two 506E Pix firewalls to use a Site to Site VPN. I can get that setup however afterwards my internet will stop working. Can anyone help me with what command I need to enter to tell the PIX to only route my VPN traffic over the VPN and all other over the internet? Also I have PAT enable because I have a e-mail server and a couple other things that Have to be accessed from the internet.
Thanks,
I can post config if needed.....
In article , t_oldham wrote: :I am trying to set up two 506E Pix firewalls to use a Site to Site VPN. :I can get that setup however afterwards my internet will stop working. :Can anyone help me with what command I need to enter to tell the PIX to :only route my VPN traffic over the VPN and all other over the internet?
show run | grep crypto_map
and look for the 'match address' clause, and edit the access-list that is shown there.
There is no specific "route this over VPN" command: anything that matches a crypto map 'match address' will go through VPN, and anything that does not match one of the 'match address' ACLs will not go through VPN.
:Also I have PAT enable because I have a e-mail server and a couple :other things that Have to be accessed from the internet.
Possibly your 'nat (inside) 0 access-list' is too inclusive.
grep, hee he... too early to troubleshoot! ;)
show run | include crypto_map
Wil my 3¢
Walter Robers> > :I am trying to set up two 506E Pix firewalls to use a Site to Site VPN.
- Create an access-list specifing the traffic to be protected by the VPN
- Use the 'split-tunnel' command with the defined access list within the 'vpngroup' command.
Command to only route my VPN traffic over the VPN and all other over the internet?
Specify in the access-list bind with the crypto process only the crypto traffic with permit string .
For example : If a tell with b in cryptography but with the world in cleartext ; a is the local network .
access-list 111 permit a a_mask b b_mask
The next default rule deny all the traffic , so all the traffic isn't encrypted ... Next link the access-list on the cryptomap
Example :
access-list 100 permit ip 10.2.2.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list 100 permit ip 10.2.2.0 255.255.255.0 10.3.3.0 255.255.255.0
crypto map newmap 10 ipsec-isakmp crypto map newmap 10 match address 110
Then . permit the traffic ipsec on the network access-list ... in the outside ..
1 ) Permit isakmp 2) Permit or esp or ah or both esp and ah
Best regards
Rocco
