service policy output problem?
Apr 20, 2005 1 Replies
prashant.goud
Pbbly you are using one the newer version of IOS ( 12.2 upwards). With new IOSs, Cisco says, "the sum of all bandwidth allocation on an interface cannot exceed 75 percent of the total available interface bandwidth. The remaining 25 percent is used for other overhead, including…
Hello,
I have a problem when I try to apply service policy to an interface this error is shown:
I/f Serial0/2 class class-default requested bandwidth 922 (kbps) Available only 666 (kbps)
my policy map is as follows:
policy-map output
class ADSL bandwidth 102 random-detect class class-default bandwidth 922 random-detect
The only way it works is if I specify bandwidth for class ADSL as 100 and specify 666 for class class-default. It seems for some reason the router thinks it only has 768kbps bandwidht but it is a 1024kbps link...
Any ideas / thoughts would be appreciated ;-)
