Hi, I am having troubles conncting 2 sites' PBXs. let's call them site A and Site B. the symptom is that when we make a call there is ringing but on the line you hear nothing (or quiet noise). you don't even hear dial\\busy tones. the session is termintaed by itself in 2-3 seconds.
The problematic site is site A. (I now that because site B is currently working fine with other siteC . therefor, i know that the connection to the pbx on site B is ok. on site B we have 3845 router with full E1 and NM-HDV2 ) .
On problematic site A there is 2611XM router installed with the IOS as follows:
System image file is "flash:c2600-ipvoicek9-mz.124-10.bin" Cisco 2611XM (MPC860P) processor (revision 4.1) with 125770K/5302K bytes of memory. Processor board ID FCZ100572MC M860 processor: part number 5, mask 2
2 FastEthernet interfaces
2 Channelized E1/PRI ports
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
the connection to the pbx is done through cross E1 cable with NM-HDV card with PVDM-12.
here is the configuration file :
version 12.4 ! hostname SiteA ! boot-start-marker boot-end-marker ! logging buffered 4096 debugging ! no aaa new-model network-clock-participate slot 1 no network-clock-participate wic 0 network-clock-select 1 E1 1/1 voice-card 1 ! ip cef ! ! isdn switch-type primary-net5 ! ! voice class h323 1 h225 timeout setup 2 call start fast ! ! ! controller E1 1/0 ! controller E1 1/1 pri-group timeslots 1-12,16 ! ! interface FastEthernet0/0 description Connection To Local LAN ip address 172.26.100.50 255.255.0.0 duplex auto speed auto ! interface FastEthernet0/1 ip address X 255.255.255.0 speed 100 full-duplex ! interface Serial1/1:15 no ip address encapsulation hdlc isdn switch-type primary-net5 isdn protocol-emulate network isdn incoming-voice voice no cdp enable ! router rip version 2 network X network Y no auto-summary ! ip route 0.0.0.0 0.0.0.0 Zzzzz ! ip http server no ip http secure-server ! ! ! control-plane ! ! ! voice-port 1/1:15 ! ! ! dial-peer voice 3000 voip destination-pattern 3... voice-class h323 1 session target ipv4: XXXX ! dial-peer voice ZZZZ pots destination-pattern MM.. direct-inward-dial port 1/1:15 forward-digits all ! ! line con 0 line aux 0 line vty 0 4 password ZZZZZZ login ! ! end
here is the log from the router after initiation a call: Mar 9 02:08:21.922: %ISDN-6-CONNECT: Interface Serial1/1:1 is now connected to 204 N/A
*Mar 9 02:08:25.840: %ISDN-6-DISCONNECT: Interface Serial1/1:1 disconnected fr om 204 , call lasted 3 seconds
*Mar 9 02:08:30.536: %DSMP-3-DSP_TIMEOUT: DSP timeout on DSP 1/15:2: event 0x6, DSMP timed out, while waiting for statistics from the DSP. DSMP State = S_DSMP_ COLLECTING_STATS
*Mar 9 02:08:30.536: chnl info(1, 15, 2)
*Mar 9 02:08:50.352: %DSPRM-5-KEEPALIVE: DSP 15 in slot 1, NOT RESPONDING - aut o restart(10 times)
*Mar 9 02:08:59.399: %DSPRM-5-UPDOWN: DSP 15 in slot 1, changed state to up
sometimes theses messages are shown also :
*Mar 1 00:29:10.994: %DSMP-3-DSPALARM: Alarm on DSP 1/12:2: status=0x1 message=
0x0 text=-
*Mar 1 00:29:10.998: chnl info(1, 12, 2)
*Mar 1 00:29:11.002: vnm_dsprm_alarm_indication_msg_proc: fatal err 1
another test that i performed: somethong is strange to me about the fact that total dsp channels allocated. is it how is suppose to be ???
SiteA#test dsp 1 Section:
1 - Query dsp resource and status
2 - Display voice port's dsp channel status
3 - Print dsp data structure info
4 - Change dsprm test Flags
5 - Modify dsp-tdm connection
6 - Disable DSP Background Status Query
7 - Enable DSP Background Status Query
8 - Enable DSP control message history
9 - Disable DSP control message history
10 - show dsp version
11 - Show alarm stats
12 - Enable dsprm alarm monitor
13 - Disable dsprm alarm monitor q - Quit
Select option : 1
Dsp firmware version: 4.4.20 Maximum dsp count: 15 On board dsp count: 3 Jukebox available Total dsp channels available 12 Total dsp channels allocated 12 Total dsp free channels 0
Querying dsp status......
*Mar 1 00:28:28.977: dsp 10 is ALIVE
*Mar 1 00:28:28.977: dsp 11 is ALIVE
*Mar 1 00:28:28.981: dsp 12 is ALIVE
Please help, Regards, Idan
