Redistributing a single static route in OSPF
Sep 06, 2006 1 Replies
I have a requirement to distribute a static route from an OSPF router to its neighbours.
However the router has several static routes configured on it, and I only want one of them to be redistributed.
The remaining static routes must not be redistributed.
Is it possible to do this. And if so, how?
thanks
Dave
You will be able to use a route map to control the redistribution.
I need to practise these (CCNP) and could have a look later
router ospf 1 redist static route-map RM.ospf.static (subnets?)
route-map RM.ospf.static 10 match ip address ACL.ospf.static
ip ascess-l s ACL.ospf.static permit ip route.address route.wildcard
Warning - whenever redistributing routes you need to take care not to create routing loops and/or redistribution loops.
