Static Route Redistribution over OSPF.
Mar 14, 2006 4 Replies
Jump to replies (4)
Static Route Redistribution over OSPF. open original image
Is it possible to redistribute Classless IP range Static routes over OSPF?
For example can I redistribute a static for IP range 10.135.64.0 /19 over OSPF, or will OSPF redistribute 10.0.0.0/8 instead?
many thanks
Dave
To redistribute static routes to subnets of classful networks use "redistribute static subnets" under the ospf router configuration.
Cisco da Gama
Another shing you should look at - now you define your OSPF areas. This command will redistribute the static route with subnetting information. Some OSPF areas (for examle, NSSA) allow you to redistribute SUMMARY address only (for exampe, you have 10.1.1.0/24, 10.100.0.0/16 and 10.0.0.0/8. OSPF may send 10.0.0.0/8 only).
Good luck,
Mike
Here is an expample: router ospf 1 log-adjacency-changes summary-address 172.16.0.0 255.255.0.0 network 10.10.102.0 0.0.0.3 area 1 network 10.10.104.0 0.0.0.3 area 1 network 10.10.105.0 0.0.0.3 area 1 network 10.10.106.0 0.0.0.3 area 1 network 10.10.107.0 0.0.0.3 area 1 network 10.10.108.0 0.0.0.3 area 1 network 10.10.109.0 0.0.0.3 area 1 network 10.10.110.0 0.0.0.3 area 1 network 10.10.188.0 0.0.0.3 area 1 network 10.10.0.0 0.0.255.255 area 1 network 172.16.103.0 0.0.0.255 area 1 network 172.16.0.0 0.0.255.255 area 1 default-information originate always ! ip classless ip route 0.0.0.0 0.0.0.0 172.16.103.45 ip route 0.0.0.0 0.0.0.0 172.16.188.47 10 ip route 10.10.0.0 255.255.0.0 Null0 ip route 170.209.0.2 255.255.255.255 172.16.103.40 ip route 170.209.0.3 255.255.255.255 172.16.103.40 ip route 172.16.0.0 255.255.0.0 Null0
