Hmmm, it's on the order books of some places, and I found a couple that *appear* to be indicating they have stock, but I'm not about to place a real order just to confirm it. 's a floating static route with icmp reachability testing. "Note: This configuration does not work for…
I have read that the ASA5505 is to be released soon - any ideas when ?
Also I have read that the V7.2, that the ASA5505 starts with, supports Dual ISP (could be that other 7.x version does aswell - i dunno) How is this done ? And how does it work ...
Regards Martin Bilgrav
Hi,I have a LAN with static configured IP telephones. All the telephones are...
W
Walter Roberson
It's a floating static route with icmp reachability testing. "Note: This configuration does not work for load balancing/load sharing."
W
www.BradReese.Com
Hi Martin,
The ASA 5505 should be on the Cisco Global Price List and available for order the first week of November 2006.
Cisco ASA 5500 Series Adaptive Security Appliances Models Comparison:
M
Martin Bilgrav
Hi Walter, and thank you for your reply.
Funny stuff about the globals and NAT statements - Why not just use "interface" in the global ? and why the NAT with an ACL ...
I dug into it abit more, as to the 5505:
backup interface and assigning VLAN to the individual switchports. Nicely done Cisco ! I like it allready
But if I want LB/LS instead, what can be done then ? (Pardon my lag of os7.x experience)
Also found some info on intra-Interface command, allowing you to route in/out the same interface. That will give som funny looking ACL for inside traffic (!)
Regards Martin
Report Content
ASAP.
