Problems with serial Interface Cisco 2600
Apr 12, 2005 1 Replies
I have a W2W link using two routers Cisco 2600, using a HDLC link but i have a lot of troubles, but i don=B4t know if may be can be the clock of the link or the tx media ???.
This is the router configuration: IPM-PCE#sh run Building configuration...
Current configuration : 839 bytes ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname IPM-PCE ! boot-start-marker boot-end-marker !
! no aaa new-model no ip subnet-zero no ip routing ! ! ! no ip cef ! ! bridge irb ! ! interface FastEthernet0/0 ip address 192.23.158.66 255.255.255.240 no ip route-cache speed auto bridge-group 1 ! interface Serial0/0 ip address 192.23.158.66 255.255.255.240 encapsulation ppp no ip route-cache no fair-queue bridge-group 1 ! ip default-gateway 192.23.158.65 ip classless ip route 0.0.0.0 0.0.0.0 192.23.158.65 no ip http server ! snmp-server community scc-b0g RO snmp-server enable traps tty bridge 1 domain 1 bridge 1 protocol ieee
! ! end
BUT I HAVE THIS ERRORS IN THE SERIAL INTERFACE, What could be the problem ?...................
IPM-PCE#sh int s0/0 Serial0/0 is up, line protocol is up Hardware is PowerQUICC Serial Internet address is 192.23.158.66/28 MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, LCP Open Open: CDPCP, BNCP, IPCP, loopback not set Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 1w3d Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 171900 packets input, 44073588 bytes, 0 no buffer Received 522 broadcasts, 2 runts, 143 giants, 0 throttles 194431 input errors, 57034 CRC, 97002 frame, 0 overrun, 0 ignored,
40395 abort 577199 packets output, 64654656 bytes, 0 underruns 0 output errors, 0 collisions, 1 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions DCD=3Dup DSR=3Dup DTR=3Dup RTS=3Dup CTS=3Dup
Check the CSU, and see if you have errors there too. If you do, and the circuit was working previously just fine, call in the circuit to your carrier.
Scott
! ! end
40395 abort 577199 packets output, 64654656 bytes, 0 underruns 0 output errors, 0 collisions, 1 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
