Hi all, from "show interface":
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops:
115667298
Are these output drops from the input queue on the interface?
Thanks Frank
Output drops, strangely enough, are packets that have been dropped because the Output queue was full. I see the potential confusion but the idea is that the semi-colon seperates the Input queue info from the "total output drops" bit. That by the way is way-too-many output…
Read the full replyHi all, from "show interface":
Thanks Frank
That by the way is way-too-many output drops. Does depend on when they ocurred of course, could be historic.
Hi Frank,
You may wish to investigate "identify five possible problem states in the interface status line of the show interfaces serial display."
Brad Reese BradReese.Com - Cisco Power Supply Headquarters
