Problem with Cisco VPN Client
May 23, 2006 2 Replies
I vpned into worked using my cell phone (dialup networking). I terminate the connection but can't access anything. Looking at the statistics on the vpn client and I'm encrypting but nothing is getting decripted. When I look at the ASA5520 sh crypto ipsec sa, it shows nothing is being encrypted nor decriped. Why is that? Any thoughts?
Thanks
In simple terms the encrypted traffic is not reaching to the device. You are using the cell phone to connect to the internet. Check if the GPRS is going through a proxy. Quickest way will be to check your ip if it is pvt it is proxied otherwise not.
traffic on UDP 500 is going through however traffic of IP->ESP is not reaching to the ASA. You can also try NAT Traversal.
you ASA config is wrong, and your client is set to encrypt everything.
