problem in connecting lansey ADSL modem with cisco catalyst 2950 switch.
Jul 13, 2006 1 Replies
I have a Cisco catalyst switch 2950 and a broadband connection of 1 mbps from BSNL. I try to connect the Broadband connection with the switch but unfortunately the communicatin between the ADSL modem and switch would not up.
The port on which I connect the ADSL modem did not show the link up status on the switch.
I already tried several possible configuration but all invain
If somebody have a Perfect solution just revert me back
With REGDS Ravi
Hi Ravi,
I dont know the ADSL Modem type, but here are some ideas -
Have you tried both a straight through cable and a X-over cable? On the Cisco, have you tried leaving Auto-negotiate on, forcing
100/full, Half/10? On the Cisco, does the interface show as down/down or up/down?
Cheers...............pk.
