PPP Authentication with AAA PPP Default records fails
Sep 14, 2006 3 Replies
Jump to replies (3)
PPP Authentication with AAA  PPP Default records fails open original image
Hello,
I got a Problem with the PPP Authentication. The BRI0 and the corresponding Dialer Statement (Fixed IP, no remote name) contain each
ppp authentication chap ms-chap callin
If the global scope contains the AAA statement
aaa authentication ppp default none
everything is allright and a Windows XP Client can dial in (no Username/Password). But with the statement
aaa authentication ppp default local
the login for a local user account is refused (Password incorrect).
Any idea ?
Hi Georg,
You may wish to investigate Troubleshooting PPP (CHAP or PAP) Authentication:
as well as Understanding and Configuring PPP CHAP Authentication:
Hope this helps.
Brad Reese BradReese.Com - Cisco Salary and Compensation Rates
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Cisco Job Databases
Hi Georg,
This may be more helpful:
username password
Sincerely,
Brad Reese Cisco CraigsList Jobs
Hello Brad,
the problem is solved ! I changed nothing (except to ms-chap-v2 Method) and created a new local account *without* using MD5 for password encryption - and it worked without a problem !
schrieb:
