Policer configuration
Jul 22, 2005 1 Replies
Policer configuration open original image
Hello,
A few days ago I posted a message about setting up the policer on a
24-ported Catalyst 3750 Switch using CLI. Unfortunately, I didn't get any (useful) replies - perhaps because my question was too inaccurate. I'll try again:
The goal is to restrict all ingress traffic on a certain port, , to bps with a level of bytes, dropping traffic if is exceeded. I did the following using the CLI:
enable configure terminal policy-map my_policy class class-default police exceed-action drop exit configure terminal interface GigabitEthernet1/0/ service-policy input my_policy end
The above had absolutely no effect on the ingress rate on port . Also, if I do a "show policy-map interface" I can see the input policy on port , but the "5 minute offered rate" shows 0 bps and no drops.
Does the switch support policing at all? Do I need to create another class than "class-default"? Is there a final "apply changes" command that I don't know of?
Thx. René Bøje Nielsen
You may find the storm control command an easier way to do this...
