pix question
Jul 26, 2005 2 Replies
I'd like to bring up the tunnel in just one direction. between
68.68.68.68 and 11.11.12.0/24 network so that internal hosts hidden behind 68.68.68.68 machine have encrypted access to 11.11.12.0/24 network but 11.11.12.0/24 network doesn't use the tunnel and is treated as any other external network out on the internet.
with this config, it works 68.68.68.68 --> 11.11.12.0/24 encrypted but
11.11.12.0/24 network has no access whatsoever.
what I need is ability to connect clear text from 11.11.12.0/24 network to the host 68.68.68.68.
-----------config ----------------------------
global (outside) 1 68.68.68.68 nat (inside) 1 0.0.0.0 0.0.0.0 0 0 timeout xlate 0:05:00 sysopt connection permit-ipsec access-list 90 permit ip host 68.68.68.68 11.11.12.0 255.255.255.0 crypto ipsec transform-set my-encr esp-3des esp-sha-hmac crypto map my_map 30 ipsec-isakmp crypto map my_map 30 match address 90 crypto map my_map 30 set peer 11.11.11.11 crypto map my_map 30 set transform-set my-encr isakmp enable outside isakmp key ******** address 11.11.11.11 netmask 255.255.255.255 isakmp policy 30 authentication pre-share isakmp policy 30 encryption 3des isakmp policy 30 hash sha isakmp policy 30 group 2 isakmp policy 30 lifetime 86400
------------------------------------------------------------------- and then I bring the tunnel up by,
no crypto map my_map interface outside clear crypto ipsec sa
clear crypto isakmp sa
- All the examples on the cisco site talk about network--network connectivity but there isn't really one that covers NAT in detail.
In article , snipped-for-privacy@yahoo.com wrote: :I'd like to bring up the tunnel in just one direction. between :68.68.68.68 and 11.11.12.0/24 network so that internal hosts hidden :behind 68.68.68.68 machine have encrypted access to 11.11.12.0/24 :network but 11.11.12.0/24 network doesn't use the tunnel and is treated :as any other external network out on the internet.
Although it wouldn't be immediately apparent to someone who didn't know PIX and IPSec well, your posting asks about 3 completely different things, some of which cannot be done but which you -probably- don't actually want to do.
Rather than pick apart your posting, I will ask you to rephrase what you want done:
- Is 68.68.68.68 the outside interface IP of your PIX, or is it an additional routable IP? (interface IPs have special properties)
- Related to the above: your posting was written in such a way that
68.68.68.68 could be a host with other hosts behind it, such as if 68.68.68.68 were a Windows box doing Internet Connection Sharing. This scenario would be inconsistant with the way you used 'global', but that might have been a misconfiguration, so better that I ask about this ?
- When the hosts fronted by 68.68.68.68 initiate connections into
11.11.12.0/24, you want the outgoing packets to be encrypted and encapsulated (tunneled), right?
- When the hosts within 11.11.12.0/24 send reply packets, should those replies be encrypted and encapsulated?
- Are there connections that the hosts within 11.11.12.0/24 should be able to initiate to the -host- 68.68.68.68 (connection sharing scenario), or should the hosts within 11.11.12.0/24 be able to ping the PIX interface IP 68.68.68.68 (PIX interface IP scenario), or should the hosts within 11.11.12.0/24 be able to initiate connections directly to the hosts hidden behind 68.68.68.68 (a tunnel scenario), or should the hosts within 11.11.12.0/24 be able to initiate connections indirectly to hosts hidden behind 68.68.68.68 by using 68.68.68.68 as the destination IP and having the PIX do port forwarding to the appropriate internal host (interface IP or public IP scenarios) ?
- When any of the above 11.11.12.0/24 initiated traffic happen, you don't want the inward traffic to be encrypted, right? How about if it were encapsulated without being encrypted?
- How about replies to 11.11.12.0/24 initiated traffic -- should the replies be encrypted? Encapsulated?
11.11.12.0/24, what IP address should the 11.11.12.0/24 hosts see them as -- the internal IPs or the 68.68.68.68 IP ?
It isn't apparent to me why you would want to do what you are asking. My -suspicion- is that your situation is perhaps a lot different than what you asked about, that you perhaps wrote in terms of what you had been thinking of as a solution to an unstated situation.
My suspicion is that your question is closer to "How can I give an internal network behind a PIX privileged access to a remote VPN'd network, without giving the remote VPN'd network privileged access back?" (e.g., if your technical support team is behind the PIX, you want the technical support to be able to have extensive access to the remote devices, but you don't want the remote devices to have special access to the technical support machines.) Asymmetric privileges is relatively easy with pure TCP, but becomes more difficult with UDP.
sorry if the post was confusing, I've replied to the questions inline but this might make it clear
68.68.68.68 is a routeable address and so is 11.11.x.x here.
192.168.10.0/24--pix--68.68.68.68----INTERNET----11.11.11.11--fw--11.11.12.0/24
- when 192.168.10.10 makes a connection to 11.11.12.0/24, it should be encrypted and present itself as 68.68.68.68 to 'fw' (the reply packets from 11.11.12.0/24 will also be encrypted)
- when 11.11.12.0/24 makes connection to 68.68.68.68 that should NOT be encrypted at all
- 11.11.12.0/24 should NOT be able to access 192.168.10.0/24 subnet by
192.168.10.x ip addresses, they must rely on the pix to do the port forwarding.
does this makes sense? like I said, I found several examples about configuring subnet--subnet VPN but none talked about this kind of situation.
Walter Robers> > :I'd like to bring up the tunnel in just one direction. between
its the outside interface
68.68.68.68 is the external interface that I need all the internal hosts 'hidden' behind.
right
yes but not connection that originates from 11.11.12.0/24
the hosts within 11.11.12.0/24 should be able to connect to "initiate connections indirectly to hosts hidden behind 68.68.68.68 by using
68.68.68.68 as the destination IP and having the PIX do port forwarding to the appropriate internal host (interface IP or public IP scenarios)"
I don't care. The only server I have is a linux box running
the replies from 68.68.68.68->11.11.12.0/24 should not be encrypted since I don't want 11.11.11.12.0/24->68.68.68.68 encrypted.
the public ip (68.68.68.68)
exactly.
