PIX PDM problem
Oct 17, 2007 1 Replies
PIX PDM problem open original image
Hi all, Im having the problem that when configuring the pix in the pdm it times out and gives a username/password error. So is there a way to change the timeout for the pdm in the pdm/cli ?
Many Thanks
Alex
.... Actually, the PDM doesn't have a timeout value.
Now, if you are losing connectivity constantly to the firewall, it is most probable a Java issue. This is because PDM is not compatible with the latest 1.6 Java version. You are most probably running that new Java release on your computer.
If you want to use the PDM without a problem, here is a java version that I know that works just fine with PDM. You will need to uninstall Java before installing this:
