pix and two internet links
Sep 19, 2008 1 Replies
Hello,
I have a pix 515E. It's possible to have two internet links (A and B) (two ISPs differents) and to have two internal networks (C and D), so that network C leaves by A and D leaves by B.
that command i need???
There is not really a way for one Cisco PIX or ASA firewall to perform this action. This is in relation to a previous post about having different inside networks route to two different Internet connections.
The problem is that a Cisco firewall, within a single context of a firewall, does not have the capability to use route-maps and policy based routing like a Cisco router. A Cisco router could declare that any traffic matching certian conditions, like an access-list specifying the internal source network, would be routed under different conditions, like using a different outgoing interface to a different Internet service provider. This would provide the solution for what you have described.
You are going to be better off purchasing a second firewall and routing the second network through the second Internet service provider. You could also declare route maps in a router which is in-line before the firewalls.
----- Scott Perry Indianapolis, IN
