cisco pix VPN routing issues
Feb 26, 2007 8 Replies
Jump to replies (8)
cisco pix VPN routing issues open original image
Hi All!
I've got 4 site-to-site VPN tunnels to PIX 515E in my central office (A). From this office I can ping branch offices B, C and D. From offices B, C and D I can also ping my central office A. However, my problem is that I can't ping office C from office B or office D from office C so on.
He is the question: is there a way to configure vpn routing for packets to travel from office B to office C via central office A? I know I can configure a vpn link between B and C but it's not an ideal scenario for me.
I do not think this is possible without a B to C VPN. The problem is in the fundamentals of VPNs. Your VPN is setup so that traffic from Site B (say 2.2.2.0/24) goes through the IPSec tunnel to Site A (say
1.1.1.0). Let's say you have the same thing setup between Site C (say 3.3.3.0/24) and Site A. For starters, anything from 2.2.2.0 does not know to take the 'A' Tunnel unless it is configured as a default route. Second, when it arrives, it is automatically pushed onto the local subnet of 'A', which even if there was another router there, would not send traffic back into the same interface to route to 'B'.
You have to remember that VPNs are setup as tunnels from LAN to LAN, and therefore traffic doesn't 'come out' of the tunnel until you are on the local subnet. In short, I'm fairly certain you need to setup a VPN directly from B to C. It might work if the VPNs were on different routers at the HQ, but I'd need to think about that some more......
You need PIX 7.x for this;
Very cool Walther. I'm more on the network side as opposed to vpn/ security, so I appreciate the link as well.
"Note: In PIX version 7.2 and later, the intra-interface keyword allows all traffic to enter and exit the same interface, and not just IPsec traffic."
Do previous versions allow IPsec traffic to do this, as it kind of suggests that 'other traffic' is the addition in this version?
Very cool Walter. I'm more on the network side as opposed to vpn/ security, so I appreciate the link as well.
7.0 introduced the intra-interface facility. 6.x and below do NOT allow traffic to go back out the same [logical] interface, even if ipsec is involved.
Could this also solve my routing problem? Would PIX 7 be able to accept a packet on the inside interface and build a VPN tunnel from the same interface?
Regards
fw
That's an unusual requirement -- usually people want to be able to accept a packet on an -outside- interface and have it go through a VPN tunnel out that same interface (to a client host or network.) But what can be done on one interface can -usually- be done on another (not *always* though.)
PIX 7 is not supported on your PIX 501. It is supported on your PIX 515 but officially requires a memory upgrade beyond the memory that the
515 series shipped with. Some people have reported success in using PIX 7.0 on a PIX 515 with relatively small configurations (e.g., don't use turbo ACLs.)
Yep - but in my setup, the PIX doesn't have the WAN link so I have to find some workaround. All attempts failed so far.
I agree.
I know. I was just wondering if it's worth getting an ASA 5505 for that job. Is it? :)
Regards
fw
