Packeteer insider question
Oct 29, 2006 1 Replies
Hey folks,
I know this is a Cisco NG, but it seems like the only place to ask.. I need a hint from someone with good packeteer knowhow:
I have got a present of Intel NetStructure Application Shaper, which happens to be rebadged Packeteer AppVantage unit, it came with very old 4.2 PacketWise release. Hardware wise it seems to be identical to PacketShaper 6500.
I have tried to upload PacketWise 7.0 image on the unit, it worked, booted up, I can access unit via CLI with full functionality but:
a) It still calls itself a Intel NetStructure Application Shaper b) It always complains about corrupt config and drops into safe mode
Total config reset does not help, obiously this is "just" a software issue, something, somewhere performs this configuration check and complains about its corruption.
Any idea how I could override those checks / reset config and make unit run newer PacketWise?
Miika
Hi Miika,
You may wish to investigate:
Packeteer's Technical Exchange
Hope this helps.
Brad Reese BradReese.Com - Cisco Technical Forums
