ospf and sub-interfaces problem
Oct 26, 2006 1 Replies
ospf and sub-interfaces problem open original image
Hi, Im running IOS 12.3(6) on a 7206(b). This problem is very similar to the problem raised by peter in
The problem description is as below
When removing the ospf network command for a sub-interface of a gig-interface, ospf neighbor relation fails for all sub-interfaces on the main interface. Neighboring routers see the neighbor in INIT state, while the router on which the change was made doesnt see any neighbors on the sub-interface at all. When doing a "sh ip ospf inteface sub-int" on the changed router, ospf will b running on the sub-interface. When pinging the multicast address 224.0.0.5 from the effected router, all neighbors reply, but pinging from neigbhros to 224.0.0.5 fails. If I ping from the neighbors to 224.0.0.6 , I recieve a reply from the effected router. Other show command outputs can be furnished on request
If peter solved this problem with an upgrade, what version of IOS did you upgrade it to?
Anybody else had the same problem and how did you solve it?
Thanks
You may wish to investigate Cisco Bug CSCed28579.
CSCed28579 Bug Details:
First Found-in Version: 12.3(5), 12.1(19)E03, 12.2(14)S05
Symptom:
An interface flaps when a service policy is attached to the interface and when it is removed.
Conditions:
The above symptom has been observed on a c7200VXR with a NPE-G1 processor board.
Currently, this has been observed on ethernet interfaces - the GigE interfaces on the NPE-G1 as well as the FastEthernet which may be present on the C7200-I/O controller.
Workaround:
The interface may be shutdown before service-policy is applied or removed.
Further Problem Description:
This is expected behaviour. When a service policy is applied to an interface, the interface has to be reset.
As a consequence, line protocol goes down then up.
Hope this helps.
