Novice needs help with Client VPN
Feb 22, 2006 0 Replies
I'm trying to setup my client vpn on a PIX 515e. I can get connected just fine, but I can not see anything on the inside network. I've attached my running config here. I thought I'd set everything up correctly and have NAT right but I still cannot see anything on the inside network. Can anyone give me any assistance?
Here is my config
PIX Version 6.3(3) interface ethernet0 auto interface ethernet1 auto interface ethernet2 auto shutdown nameif ethernet0 outside security0 nameif ethernet1 inside security100 nameif ethernet2 dmz security50 enable password Hvup11B1njUIaHN3 encrypted passwd Hvup11B1njUIaHN3 encrypted hostname cerberus domain-name mycompany.com clock timezone EST -5 no fixup protocol dns fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 no fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names name 192.43.244.18 time.nist.gov access-list acl-out permit tcp any any eq ftp-data access-list acl-out permit tcp any any eq ftp access-list acl-out permit icmp any 1x.x.x.0 255.255.255.0 access-list acl-out permit tcp any eq ssh interface inside access-list acl-out permit tcp interface outside eq ssh any eq ssh access-list acl-out permit tcp any host 1x.x.x.20 eq www access-list acl-out permit tcp any host 1x.x.x.x eq 3389 access-list acl-out permit tcp any host 1x.x.x.x eq www access-list acl-out permit tcp any host 1x.x.x.x eq smtp access-list acl-out permit tcp any host 1x.x.x.x eq 3389 access-list acl-out permit tcp any host 1x.x.x.x eq pop3 access-list acl-out permit tcp any host 1x.x.x.x eq imap4 access-list acl-out permit icmp any 1x.x.x.0 255.255.255.0 echo-reply access-list acl-out permit udp host 1x.x.x.x host 1x.x.x.x eq snmp access-list acl-out permit tcp any host 1x.x.x.x eq www access-list acl-in permit ip host 192.168.128.2 any access-list acl-in permit ip host 192.168.128.3 any access-list acl-in permit ip host 192.168.128.10 any access-list acl-in permit ip host 192.168.128.16 any access-list acl-in permit ip host 192.168.128.25 any access-list acl-in permit ip host 192.168.128.27 any access-list acl-in permit ip host 192.168.128.36 any access-list acl-in permit ip host 192.168.128.74 any access-list 101 permit ip 192.168.128.0 255.255.255.0 10.99.99.0
255.255.255.0 pager lines 24 logging on logging trap debugging logging host inside 192.168.128.16 icmp deny any outside mtu outside 1500 mtu inside 1500 mtu dmz 1500 ip address outside 1x.x.x.x 255.255.255.0 ip address inside 192.168.128.22 255.255.255.0 ip address dmz 172.16.10.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm ip local pool vpnpool 10.99.99.1-10.99.99.254 pdm location 192.168.128.3 255.255.255.255 inside pdm location 192.168.128.11 255.255.255.255 inside pdm location 192.168.128.15 255.255.255.255 inside pdm location 192.168.128.20 255.255.255.255 inside pdm location 192.168.128.25 255.255.255.255 inside pdm history enable arp timeout 14400 global (outside) 1 1x.x.x.x nat (inside) 0 access-list 101 nat (inside) 1 192.168.128.0 255.255.255.0 0 0 static (inside,outside) 1x.x.x.x 192.168.128.20 netmask 255.255.255.255
0 0 static (inside,outside) 1x.x.x.x 192.168.128.11 netmask 255.255.255.255
0 0 static (inside,outside) 1x.x.x.x 192.168.128.3 netmask 255.255.255.255
0 0 static (inside,outside) 1x.x.x.x 192.168.128.25 netmask 255.255.255.255
0 0 static (inside,outside) 1x.x.x.x 192.168.128.31 netmask 255.255.255.255
0 0 access-group acl-out in interface outside access-group acl-in in interface inside route outside 0.0.0.0 0.0.0.0 1x.x.x.x 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server RADIUS protocol radius aaa-server LOCAL protocol local ntp authentication-key 1 md5 ******** ntp authenticate ntp trusted-key 1 ntp server time.nist.gov source outside prefer http server enable http 192.168.128.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-ipsec sysopt connection permit-pptp crypto ipsec transform-set myset esp-des esp-md5-hmac crypto dynamic-map dynmap 10 set transform-set myset crypto map mymap 10 ipsec-isakmp dynamic dynmap crypto map mymap client configuration address initiate crypto map mymap client configuration address respond crypto map mymap interface outside isakmp enable outside isakmp key ******** address 0.0.0.0 netmask 0.0.0.0 isakmp identity address isakmp client configuration address-pool local vpnpool outside isakmp policy 10 authentication pre-share isakmp policy 10 encryption des isakmp policy 10 hash md5 isakmp policy 10 group 1 isakmp policy 10 lifetime 86400 isakmp policy 20 authentication pre-share isakmp policy 20 encryption des isakmp policy 20 hash md5 isakmp policy 20 group 2 isakmp policy 20 lifetime 86400 vpngroup hsvpn address-pool vpnpool vpngroup hsvpn dns-server 192.168.128.3 vpngroup hsvpn wins-server 192.168.128.1 vpngroup hsvpn default-domain mycompany.com vpngroup hsvpn idle-time 1800 vpngroup hsvpn password ******** telnet 192.168.128.0 255.255.255.0 inside telnet timeout 5 ssh 192.168.128.0 255.255.255.0 inside ssh timeout 5 console timeout 0 vpdn group 1 accept dialin pptp vpdn group 1 ppp authentication pap vpdn group 1 ppp authentication chap vpdn group 1 ppp authentication mschap vpdn group 1 ppp encryption mppe 40 vpdn group 1 client configuration address local vpnpool vpdn group 1 pptp echo 60 vpdn group 1 client authentication local vpdn username hsvpn password ********* vpdn enable outside terminal width 80 Cryptochecksum:18674da1476e626ff236c501d1d3f7ca : end
