Help with setting up Easy VPN client on PIX
Mar 31, 2006 0 Replies
Hi all,
I'm trying to setup Easy VPN between our main site and an overseas site but having troiuble with the config for the client end. They are using a PIX501 as the client and I have a router here to act as the server. This block of config I have to add for the client end:
crypto ipsec client ezvpn vpn1 cinnect auto group vpn1 key blahblah mode client peer x.x.x.x username bigjohn password blahblah2
isn't something I can do for their PIX. Is their an equivalent command I have to run to set this up right? Do I have to make any further changes from the server end to indicate that its going to be handling a PIX or it doesn't matter as long as they support easy vpn?
Thanks!
