Not able to send mails through pix 506e
Mar 13, 2007 1 Replies
Hi I have pix 506e firewall, D-link ADSL dsl-502t and my IBM xseries 236 server. I have fix static live ip 59.181.103.220 which i have got from ISP. loyalindia.co.in is my domain, The MX record for it is mail.loyalindia.co.in which points to
59.181.103.220
My problem is i am not able to send mails ( with my mail server, Exchange server,loyalindia.co.in) through pix 506e but i am receiving mails from any server.
I have tried with (ADSL) natting and without natting but the problem is same. If i am removing the pix 506e and directly connecting the server to adsl i am able to receive and send mails properly
My network design is as fallows:- ADSL (WAN) 59.181.103.220 ADSL (LAN)59.181.103.221 Pix 506e (out) 59.181.103.222 Pix 506e (in) 192.168.1.1. My domain mail server loyalindia.co.in (Exchange server) ip
192.168.1.2
My config as fallows:- PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 auto nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password oH2xz4N6pxtBHe8N encrypted passwd.2KYencrypted hostname loyal domain-name loyalfire.com fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 no fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names name 59.181.103.221 adsl name 192.168.1.2 mail access-list smtp_in permit tcp any interface outside eq smtp access-list smtp_in permit tcp any host 59.181.103.222 eq smtp access-list out_in permit tcp any interface outside eq smtp pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside 59.181.103.222 255.255.255.0 ip address inside 192.168.1.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm location mail 255.255.255.255 inside pdm location adsl 255.255.255.255 outside pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) tcp interface smtp mail smtp netmask
255.255.255.255 0 0
access-group out_in in interface outside route outside 0.0.0.0 0.0.0.0 adsl 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http mail 255.255.255.255 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable telnet timeout 5 ssh timeout 5 console timeout 0 terminal width 80 Cryptochecksum:496f7c38801fe5cffecbc0ba6381a49d : end loyal(config)# exit loyal# exit
Logoff
Type help or '?' for a list of available commands. loyal> en Password: ***** loyal# config t loyal(config)# logging on loyal(config)# logging timestamp loyal(config)# logging monitor warnings loyal(config)# logging buffered warnings loyal(config)# logging trap warnings loyal(config)# sh run : Saved : PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 auto nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password oH2xz4N6pxtBHe8N encrypted passwd 2KFQnbNIdI.2KYOU encrypted hostname loyal domain-name loyalfire.com fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 no fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names name 59.181.103.221 adsl name 192.168.1.2 mail access-list smtp_in permit tcp any interface outside eq smtp access-list smtp_in permit tcp any host 59.181.103.222 eq smtp access-list out_in permit tcp any interface outside eq smtp pager lines 24 logging on logging timestamp logging monitor warnings logging buffered warnings logging trap warnings mtu outside 1500 mtu inside 1500 ip address outside 59.181.103.222 255.255.255.0 ip address inside 192.168.1.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm location mail 255.255.255.255 inside pdm location adsl 255.255.255.255 outside pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) tcp interface smtp mail smtp netmask
255.255.255.255 0 0 access-group out_in in interface outside route outside 0.0.0.0 0.0.0.0 adsl 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
anybody who can support me?.
This is the problem here, you say that your MX/A record for your mail server point to 59.181.103.220 but your NAT statement on the PIX is for
59.181.103.222 which the SMTP port is reachable from the internet.
I would suggest changing your A record for your mail server from
59.181.103.222 instead of 59.181.103.220 as .220 is the interface of your ADSL router not the PIX.
