PIX losing ARP?
Oct 09, 2007 6 Replies
Chad Mahoney
Can you do a show version on the PIX, what license feature does it have? Is there any other devices in your network? Switches, printers, etc... If there are do you see those devices in ARP?
Hello all, I have a Cisco PIX 501 version 6.3(5). It is deployed in an office with 10 PCs, all with web access. Every day (at different times) one or two of the PCs will lose internet browsing connectivity. When they are unable to browse I can still ping internet hosts i.e. yahoo.com. If I reboot the PIX connectivity is restored. Has this got something to do with the PIX losing it's ARP cache? I reloaded the software (went from 6.3.(4) to 6.3(5)) and it still does this daily. The ARP timeout is set to the 4 hour default. Please see config below and thank you very much for any help you can give.
PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password XXXXXXXXXXXXXXXX encrypted passwd XXXXXXXXXXXXXXXXX encrypted hostname PIX domain-name ciscopix.com fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names name 192.168.1.5 Server name xxx.xxx.xxx.xxx NOSPAM name xxx.xxx.xxx.xxx REMOTESUPPORT access-list outside_access_in permit tcp any host xxx.xxx.xxx.xxx eq pop3 access-list outside_access_in permit tcp NOSPAM 255.255.255.0 host xxx.xxx.xxx.xxx eq smtp access-list outside_access_in permit tcp host REMOTESUPPORT host xxx.xxx.xxx.xxx eq 3389 access-list inside_access_out permit ip any any access-list 100 permit icmp any any access-list 100 permit tcp any any eq pop3 access-list 100 permit tcp any any eq smtp access-list 100 permit tcp any any eq www access-list 100 permit tcp host REMOTESUPPORT interface outside eq
3389 access-list 200 permit ip any any pager lines 23 logging timestamp logging host inside Server mtu outside 1500 mtu inside 1500 ip address outside xxx.xxx.xxx.xxx 255.255.255.224 ip address inside 192.168.1.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm location Server 255.255.255.255 inside pdm location REMOTESUPPORT 255.255.255.255 outside pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 192.168.1.0 255.255.255.0 0 0 static (inside,outside) tcp interface smtp Server smtp netmask
255.255.255.255 0 0 static (inside,outside) tcp interface pop3 Server pop3 netmask
255.255.255.255 0 0 static (inside,outside) tcp interface 3389 Server 3389 netmask
255.255.255.255 0 0 static (inside,outside) tcp interface www Server www netmask
255.255.255.255 0 0 access-group 100 in interface outside access-group 200 in interface inside rip inside passive version 1 route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.1 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http 192.168.1.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps sysopt noproxyarp inside floodguard enable telnet 192.168.1.0 255.255.255.0 inside telnet timeout 5 ssh timeout 5 console timeout 0 terminal width 80 Cryptochecksum:2ec097def00342437621caa23cbc545b : end
Chad, here is the sh ver and the ARP table. The most recent entry to drop is the "inside 192.168.1.74 001a.a018.9a4f" entry. There are two network printers that do not show up in ARP, neither does the unmanaged switch. Just the PCs and Windows server.
sh arp outside 24.248.210.1 0050.5701.fc00 inside 192.168.1.78 0011.43a3.655e inside Server 00c0.9f1e.2b24 inside 192.168.1.67 0011.43a3.73f9 inside 192.168.1.66 00c0.f074.00a1 inside 192.168.1.64 001a.a03a.8904 inside 192.168.1.82 0012.1784.247a inside 192.168.1.76 0011.43a3.4d39 inside 192.168.1.75 000b.dbc2.cc16 inside 192.168.1.74 001a.a018.9a4f inside 192.168.1.79 0011.43a3.75b9 inside 192.168.1.68 0011.43a3.68de PIX# sh arp statistics Dropped blocks in ARP: 6 Maximum Queued blocks: 4 Queued blocks: 0 Interface collision ARPs Received: 0 ARP-defense Gratuitous ARPS sent: 0 Total ARP retries: 28 Unresolved hosts: 0 Maximum Unresolved hosts: 3
Thanks!
sh ver
Cisco PIX Firewall Version 6.3(5) Cisco PIX Device Manager Version 3.0(4)
Compiled on Thu 04-Aug-05 21:40 by morlee
SChamberPIX up 1 hour 51 mins
Hardware: PIX-501, 16 MB RAM, CPU Am5x86 133 MHz Flash E28F640J3 @ 0x3000000, 8MB BIOS Flash E28F640J3 @ 0xfffd8000, 128KB
0: ethernet0: address is 0013.80b7.4ac8, irq 9 1: ethernet1: address is 0013.80b7.4aca, irq 10 Licensed Features: Failover: Disabled VPN-DES: Enabled VPN-3DES-AES: Enabled Maximum Physical Interfaces: 2 Maximum Interfaces: 2 Cut-through Proxy: Enabled Guards: Enabled URL-filtering: Enabled Inside Hosts: 10 Throughput: Unlimited IKE peers: 10
This PIX has a Restricted (R) license.
Serial Number: 809115275 (0x303a1e8b) Running Activation Key: 0xedbcba40 0x58d16a67 0x76c33629 0x63886482 Configuration has not been modified since last system restart.
Just by looking at the ARP table you have 11 hosts and only 10 licenses. I would say your problems begin there. Just from looking at the table, I would say there is your problem. Could you perform a sh xlate command and look at the translations being performed.
I have had the same symptoms you descibed, it was the license count... only short term fix was to shorten the xlate time... real solution is a 50 user upgrade..
Thank you both very much for your help. I will upgrade.
