I have a Netflow collector program on a server in my datacenter and and pointing all my routers at the collector to gather statistics. However, there is one router for which this does not work. It's a
3725 running VRF-Lite between a private-LAN and public-Internet side (the T1 is split on two different DLCI's). These map to FastEthernet0/0 and FastEthernet0/1 respectively.
I'm guessing the VRF is the problem, since my LAN side is within the VRF, but my Netflow collector is not receiving any info from this router. I even tried using "ip flow-export source FastEthernet0/0" to insure that the packets are sourced from an interface with the VRF on the LAN side. No dice.
Any other ideas I could try?
-Bob
