cisco and telewest
Aug 02, 2007 2 Replies
an anyone point me in the right direction, this is my config:
Router#show running-config Building configuration...
Current configuration : 1001 bytes ! version 12.1 no service single-slot-reload-enable service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname Router ! no logging buffered no logging buffered logging rate-limit console 10 except errors enable secret 5 xxxx enable password xxxx ! memory-size iomem 20 ip subnet-zero no ip routing no ip finger ip name-server 62.31.176.39 ip name-server 62.249.250.90 ip name-server 194.117.134.19 ! ! ! ! interface Ethernet0 ip address 192.168.2.1 255.255.255.0 ip nat inside no ip route-cache half-duplex ! interface FastEthernet0 ip address dhcp ip nat outside no ip route-cache speed auto full-duplex ! interface Serial0 no ip address no ip route-cache shutdown ! ip nat inside source list 102 interface FastEthernet0 overload ip classless no ip http server ! access-list 102 permit ip 192.168.2.0 0.0.0.255 any ! line con 0 transport input none line aux 0 line vty 0 4 password xxxx login ! end
from here the router I can ping anywhere, from the PC I can ping the LAN and WAN side of the router but nothing beyond it
can anyone help?
Hi Kevin,
... deleted ...
It looks like you need a default route to your Gateway (next hop address)...
Cheers...............pk.
To me it looks like the issue here is not with the gateway as the router itself is supposed to act like it. If it needs a default route it should be passed with the dhcp information from interface Fa0. The big issue here is that the ip routing command is disabled (no ip routing) which prevents the router from routing the packets between and to other subnets.
-- Leander de Graaf
