let's say I have a device supporting VRF and I have defined 2 VRFs (A & B) with
2 interfaces each, say A1 & A2 and B1 & B2.
AFAIK those VRFs are independent and each one groups some interfaces of the device.
Then, if I want to link two of the VRFs I need another router with 2 interfaces (say C1 & C2) that share the same LAN segment with one of the VRF. I mean
C1 belongs to the same LAN segment of B1 and C2 belongs to the same LAN segment of A2. All the layer 3 parameters set up accordingly Am I correct? I hope so.
My question is:
can I use a third VRF on the same device in order to do that? Maybe is not a common practice but I want to know whether it is possible or not.
TIA Alex.
Hi,I am working with LACP for past 1 year. I have the following doubt.Consider a...
E
egjose
with 2 interfaces each, say A1 & A2 and B1 & B2.
Hi, I think that you have to use "Multiprotocol BGP (MP-BGP)" to share the routes between VRFs. You don't need other Router or VRF (is possible, but not necesary).
See:
Jose.
J
jlaidlaw
The scenario you are describing is commonly referred to as "VRF lite" because you are connecting two vrf's together without bgp. Normally, the vrf's routes are tagged internally with the route distinguisher, or RD. This value is assigned to the vrf when you create it, like rd
1:1, or rd 192.168.1.1:4532. The routes will be self contained, but you can share routes with MBGP. So you need to tell the vrf what routes you want to put into bgp and what routes you want to take out of bgp, so you use the route-target import and route-target export commands. You can reuse the RD value or use another value, and it is these values that allow you to share routes between vrf's with BGP. ex.
ip vrf a rd 100:100 route-target export 100:100 route-target import 255:275 ! ip vrf b rd 200:200 route-target export 255:275 route-target import 100:100 ! int e 0/2 ip vrf forwarding a ip add 1.1.1.1 255.255.255.0 ! int e 0/3 ip vrf forwarding b ip add 2.2.2.2 255.255.255.0 ! router bgp 65514 ! address-family ipv4 vrf a network 1.1.1.0 mask 255.255.255.0 ! address-family ipv4 vrf b network 2.2.2.0 mask 255.255.255.0
This config will share all the routes from one vrf with the other. If you want to only share some of the routes, then remove the route- target export statements, and use an "export map". ie.
ip prefix-list vrfa-nets permit 1.1.1.0/24 ip prefix-list vrfb-nets permit 2.2.2.0/24
route-map vrfa-export match ip add prefix vrfa-nets set extcommunity rt 100:100 ! route-map vrfb-export match ip add prefix vrfb-nets set extcommunity rt 255:275 ! ip vrf a no route-target export 100:100 export map vrfa-export ! ip vrf b no route-target export 255:275 export map vrfb-export !
then do a "clear ip bgp *"
Rack1R3(config-router)#do sh ip bgp vpn all BGP table version is 7, local router ID is 172.16.3.3 Status codes: s suppressed, d damped, h history, * valid, > best, i - internal, r RIB-failure, S Stale Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path Route Distinguisher: 100:100 (default for vrf a)
*> 1.1.1.0/24 0.0.0.0 0 32768 i
*> 2.2.2.0/24 0.0.0.0 0 32768 i Route Distinguisher: 200:200 (default for vrf b)
Rack1R3(config-router)#do sh ip route vrf a
Routing Table: a Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2 E1 - OSPF external type 1, E2 - OSPF external type 2 i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2 ia - IS-IS inter area, * - candidate default, U - per-user static route o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
1.0.0.0/24 is subnetted, 1 subnets C 1.1.1.0 is directly connected, Ethernet0/2 2.0.0.0/24 is subnetted, 1 subnets B 2.2.2.0 is directly connected, 00:00:46, Ethernet0/3 Rack1R3(config-router)#do sh ip route vrf b
Routing Table: b Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2 E1 - OSPF external type 1, E2 - OSPF external type 2 i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2 ia - IS-IS inter area, * - candidate default, U - per-user static route o - ODR, P - periodic downloaded static route
1.0.0.0/24 is subnetted, 1 subnets B 1.1.1.0 is directly connected, 00:00:49, Ethernet0/2 2.0.0.0/24 is subnetted, 1 subnets C 2.2.2.0 is directly connected, Ethernet0/3
A
AM
Thank you so much all of you guys!!!
Alex.
A
andriyk
Hello, I've got a similar requirement for the network. I need to share directly connected routes between two VRFs on one router (6509) As far as I understand, sharing routing tables between VRFs requires the bgp, doesn't it? I've tried the approach described in your discussion. I'll explain briefly the relevant configuration (it's ~30K file):
M
Matthew Melbourne
Yes, BGP need to be running to leak routes between two different VRFs, and it does work on one router without any neighbours configured.
Do you have at least one interface in the global routing table, otherwise the mBGP won't start; I've just tried your config in the lab, and until I created a loopback in the global routing table, the BGP routes didn't appear. Also, I've added "no synchronisation" and "no auto-summary" under the two vrf instances, and the global instance. Instead of the network statements (which will work), you could consider "redistributed connected" and "redistribute static" (if required).
My working configuration is included below:
! ip vrf BLUE rd 65000:200 route-target export 65000:200 route-target export 65000:100 route-target import 65000:200 route-target import 65000:100 ! ip vrf RED rd 65000:100 route-target export 65000:100 route-target export 65000:200 route-target import 65000:100 route-target import 65000:200 ! ip cef ! interface Loopback0 ip address 10.0.0.1 255.255.255.255 ! interface FastEthernet0/0 no ip address no keepalive duplex auto speed auto ! interface FastEthernet0/0.100 encapsulation dot1Q 100 ip vrf forwarding RED ip address 10.0.100.1 255.255.255.0 ! interface FastEthernet0/0.200 encapsulation dot1Q 200 ip vrf forwarding BLUE ip address 10.0.200.1 255.255.255.0 ! router bgp 65000 no synchronization bgp log-neighbor-changes no auto-summary ! address-family ipv4 vrf RED no auto-summary no synchronization network 10.0.100.0 mask 255.255.255.0 exit-address-family ! address-family ipv4 vrf BLUE no auto-summary no synchronization network 10.0.200.0 mask 255.255.255.0 exit-address-family
Router#sh ip bgp vpnv4 vrf RED BGP table version is 7, local router ID is 10.0.0.1 Status codes: s suppressed, d damped, h history, * valid, > best, i - internal Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path Route Distinguisher: 65000:100 (default for vrf RED)
*> 10.0.100.0/24 0.0.0.0 0 32768 i
*> 10.0.200.0/24 0.0.0.0 0 32768 i
Router#sh ip route vrf RED Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2 E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2 ia - IS-IS inter area, * - candidate default, U - per-user static route o - ODR, P - periodic downloaded static route
10.0.0.0/24 is subnetted, 2 subnets C 10.0.100.0 is directly connected, FastEthernet0/0.100 B 10.0.200.0 is directly connected, 00:07:50, FastEthernet0/0.200
Router#ping vrf RED ip 10.0.200.1
Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 10.0.200.1, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Cheers,
Matt
A
andriyk
Hello Matthew, All my interfaces are in VRFs, so the global table is empty. I will try your advice with Loopback. (I've actually tried before "redistribute" and "no synchronization" and "no auto-summary". It did not work). Could be exactly your suggestion, that global table effects the BGP routes ramification. As soon as I'm at the console, I'll try and share my results! Regards,
- andrey
Report Content
ASAP.
