Need help for Dynagen Config
Sep 30, 2008 2 Replies
On dynagen ,I have configured a full mesh frame-relay ,I am using default configuration for frame-relay.I am able to ping every remote router in my full mesh topology.The problem that i am facing is I am not able to ping my serial interface IP from the router itself. I dont know if its a IOS bug or some configuration error or may be somethig wrong with Dynagen..below is my interface config and sh ver for your ref..
== R4#sh run int s0/0 Building configuration...
Current configuration : 141 bytes ! interface Serial0/0 ip address 148.1.1.4 255.255.255.0 encapsulation frame-relay serial restart-delay 0 frame-relay lmi-type ansi end ======= R4#sh ver Cisco Internetwork Operating System Software IOS (tm) 3600 Software (C3640-IK2S-M), Version 12.1(27b), RELEASE SOFTWARE (fc1) Copyright (c) 1986-2005 by cisco Systems, Inc. Compiled Wed 17-Aug-05 02:07 by pwade Image text-base: 0x60008940, data-base: 0x60F06000 ========
Any suggation will be a great help...Thanks..
Do "show frame-relay map". You should find you have a map for each remote addresss but not for 148.1.1.4.
If you want to ping your own interface address in multipoint frame-relay like this you need to statically configure a map for the interface address, e.g.
! interface Serial0/0 ... frame-relay map ip 148.1.1.4 ... !
