NAT question.
Mar 15, 2008 2 Replies
Hello,
I have cisco 4000 series router, 2 Ethernet and 2 FastEthernet ports.
I have 10.10.10.0/24 net connected to Fa0. This net is natted to Eth0 public IP address A.B.C.D. A.B.C.D is destination natted to 10.10.10.200 (local server available from public Internet).
Moreover I have 192.168.0.0/24 net connected to Fa1. This net is natted to Eth1 public IP address X.Y.Z.W
I would like to connect from 192.168.0.0/24 to A.B.C.D and be redirected to 10.10.10.200.
Is this possible to achieve?
Regards, Jarek
Wow, thatis an *old* router! I hope this isn't running in production anywhere!
I'm sure the list can correct me if I am wrong, but I don't think that redirection per se is possible with NAT since NAT translates 1 IP to 1 IP or pool of IP addresses.. Usually redirection happens in L7. Now if you are using the word redirection and really mean translation, then yes, NAT is exactly that. However, I would imagine that you would have to set up some sort of policy-based routing on the router based on your conditions you listed above. Of course that all depends if you can set up policy-based routing to translate your internal IP addresses differently.
I think this is why Cisco came out with zone-based firewalls.
Google for "NAT on a stick".
