Multiple IP addresses for Dialer0
Jul 17, 2007 3 Replies
Jump to replies (3)
How can I configure additional external IP addresses for the cisco877-K9 router ?
I need this as I have a number of webservers behind the router.
I am using ADSL PPPoE and have 5 IP addresses to assign to the router but can only manage to make one work. IOS or SDM solutions are fine.
Do you want to NAT them or route them? Are you trying to use that range behind your router, or are you running a private range and NATing them?
I would guess NAT, in which case you don't put more IPs on Dialer0, but instead use additional 'ip nat inside' statements specifying the outside IP mapping to the inside IP, and don't worry about the Dialer0 interface.
You need to use static nat for the other addresses.
