Multilink PPP: how many links?
Apr 21, 2005 2 Replies
Bob
Three is safe. Four may start giving you problems depending on whether they are private lines or connecting to an ISP. Technically you can do six (or eight?) but I wouldn't recommend it.
Hi, I'm currently using 'multilink ppp' to link together two 2 Mbps, with optimal results. Now, I need to increase total bandwidth. Does 'multilink ppp' scale well adding two or three links?
Thanks Mimmus
Technically we support (depending on the IOS version) up to 64 or
255 member links in one MLPPP bundle.
Whether that will perform adequately is a function of:
- the router CPU power relative to the aggregate bandwidth of the links
- the variability in latency/jitter across the member links
In the o.p.'s case, I'd recommend looking at the CPU load when both links are full.
One option for reducing CPU load when running multilink CPU: disable link-layer fragmentation.
Aaron
