Multicast / Broadcast "filtering" on 2950
Aug 25, 2006 4 Replies
Jump to replies (4)
Multicast / Broadcast "filtering" on 2950 open original image
Hi all,
is there a command how to activate the filtering of Multicast/Broadcast.
The last couple weeks we have quiet often the Problem with a MC / BC Storm and the Network goes down really bad.
I activated the Automatic Control under the HP switches now but don't know the command for the Cisco devices (2950 / 35XX)
Thank you in advance
BR Heiko
Configuring Port-Based Traffic Control
Would seem to be what you need.
Try the storm-control statement on the interfaces. Look at the options, you can define percentages of bandwidth from the physical port to let broadcasts/multicasts through.
FW
Thank you for the quick response. Does anybody have a good number for the level?
50??
Thank you
/Heiko
NO_spamm schrieb:
Your problem is most likely being caused by a spanning-tree loop. Storm-control is not going to fix the problem, it will only cause a different one. You need to investigate why and where this is happening. Map out you layer 2 network connections and figure out where to break connections to break the network into separate ones. Do this in advance so the next time you see the problem you have a game plan for trying to figure out why it is happening.
Scott
