catOS on 4506
Aug 25, 2006 6 Replies
Jump to replies (6)
See figures 10.5 and 10.6 at
As a more tip if you have a linux machine you can run OpenVMPS. I tried it, it's fine. That might solve your problem because Cisco switches are requested just to act as VMPS(open) clients.
Alex.
As far as I know with the IOS you have anyway the VMPS client and using OpenVMPS you are OK.
Moreover do you know if the "blocking ports" policy of the server applies to VLANs? The scenario I have in mind is:
You have rooms where sockets are less than people who need to use them. So virtually you could use 2 switches (that can not behave as VMPS client) with VLANs and strictly tie each port of the
1st switch to a port on the 2nd switch. Then you can go from the 2nd switch to a switch that act as VMPS client. If you could restrict access (VMPS way,i.e. supposing just one MAC address per VLAN - ok VLAN weren't born for this purpose) to an entire VLAN you would avoid the use of the second switch using the trunk link and would avoid to use a lot of cables to connect the ports of the 2nd switch to the VMPS client.
The only disadvantage of this solution is that you share the bandwidth of the trunk between the 2 switches but if you use a gigabit link, is not such a problem.
Alex.
VMPS is clearly on the way out of not being supported by Cisco, it was never really supported, some historical info somebody posted once is that some large customer asked for it, cisco did it for them, and then they switched gears.
I wouldn't implement it now.
The replacement would be 802.1X. Modern WinXP and Mac OSX (and unix workstations) all can support .1X. You can assign the VLAN from .1X during the authentication phase and you can disable it per port if you really need to for non-workstation type gear (ie. printers, etc.).
