Mixed Pix-to-Pix and Remote Access
Aug 16, 2005 3 Replies
Jump to replies (3)
I've created the needed configuration for the Remote Access portion of the VPN, but I need to figure out how to support Pix-to-Pix configuration.
I should also say that the PIX OS is 7.0 and the remote access runs with AAA running off of Microsoft IAS on a 2003 domain controller.
do I need to create a seperate crypto map with each of the 3 branches as peers via "set peer" ?
You may wish to investigate the online Cisco Security PIX TAC Case / Knowledge Base:
http://129.41.16.73/security/home Hope this helps,
Brad Reese Free Cisco Security Upgrades:
BradReese.Com Cisco Repair Service Experts
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 U.S./Canada Toll Free: 877-549-2680 International: 828-277-7272 United Kingdom: 44-20-70784294
In article , Fuzzy Britches wrote: :do I need to create a seperate crypto map with each of the 3 branches :as peers via "set peer" ?
No, there should be one crypto map per interface. If you have multiple VPN terminating on the same interface, then they are differentiated by using different policy numbers.
