linksys rv042 +cisco 2600 +ipsec +two subnets
Apr 21, 2006 0 Replies
It is necessary to attach the remote point using ipsec to a network . A problem that at adjustment vpn on linksys in remote group setup it is possible to specify only subnet or a range. How route on two subnets through one interface ipsec?
!cisco config ! crypto map FAMA 1 ipsec-isakmp set peer ******* set transform-set IRMA match address tunneler ! ! interface Loopback1 ip address 10.1.17.1 255.255.255.252 ip access-group 115 in ip access-group 115 out no ip redirects no ip proxy-arp no ip mroute-cache crypto map FAMA ! ip route 10.1.18.0 255.255.255.240 Loopback1
Without this rule it is not established ipsec connection
ip access-list extended tunneler permit ip 10.1.18.0 0.0.0.15 10.1.11.0 0.0.0.255 permit ip 10.1.11.0 0.0.0.255 10.1.18.0 0.0.0.15
