6509 - Sup720 - IPX
Apr 21, 2006 5 Replies
Jump to replies (5)
Is there an IOS images that supports IPX for a 6509 with a Sup720? I've used their feature navigator but can't find it.
I don't need to route IPX put I do need to switch (layer2)
layer 2 switching is not protocol dependent
are you encountering some difficulty ?
No, I was just trying to use protocol-filtering to keep IPX off of a couple of ports, and didn't see the command in the IOS I had. Wasn't for sure if it was the image I am using or if it's depricated.
are you referring to "switchport protocol ipx off" ?
I was thinking there at one time were the following commands:
(global) protocol-filter
then yes,
I see those command options in IOS 12.1E for a SUP 1 but nothing more recent ...
