LEAP & ACS Alternatives
May 27, 2005 2 Replies
Hello,
We have a large installed base of Aironet 1200 Access Points at our main locations, and we also have some smaller sites that also need wireless access. These smaller sites are connected back to the main location via VPN.
We are currently doing LEAP for security and we use Cisco ACS Solution Engines for security. We use the ACS for user administration, and also for restricting MAC addresses that are allowed on the network.
The question is, since I don't really want to be dependant upon the VPN connection back to the main office to connect to the ACS to run these remote wireless networks, are there any other reasonable alternative ways to provide at least MAC lockdown security. I could obviously lock down each access point individually to certain MAC's, but that becomes an administration nightmare because assuming your users will roam, you would have to put the MAC manually in every single AP.
Here are the ideas we have thought of so far:
  1. Use the ACS for authentication (not preferred because we must also rely on our VPN tunnel staying up for the wireless to work)
  2. Use a 3rd Party ACS (probably not cost effective, plus it means running an additional server at each site)
  3. Possibly use Kiwi CatTools to script out the MAC lockdowns to each AP (we already own CatTools, so it is free, but probably still a lot of administration)
MAC lockdowns are the absolute minimum security we would need, obviously the more the better. I am open to any other ideas.
Thanks for any advice.
N. Hall schrieb:
Starting with IOS 12.2(15)JA you can setup an AP as WDS and this one can use it's local MAC authentication to all registered AP. So you'll only need to put the MAC addresses on the WDS (and a backup WDS).
Works great as long as the number of addresses fits in startup-config
MAC lockdown isn't really any security measure. An attacker will read valid MACs from beacons and association/disassociation requests.
Recent IOS's support an internal radius database which you can use as a fall-back mechanism. Configure the internal radius on one of the access-points at the remote location so your users (or at least the most important users) can have wireless access in case the VPN connection goes doen. You only need to configure one (or two for redundancy) access-points internal-radius on the remote location and point all other access-points to use that access point in case the VPN fails.
Erik
