Layer 2 Ether channel
Jan 30, 2007 2 Replies
Layer 2 Ether channel open original image
Hi all,
A little query.
I have just set-up Ether channel between two Cisco 3750s. I'm using layer 2 ether channel using two ports on each switch.
Everything is identical and seems to work and fail-over OK. i.e. when I drop one of the links in the bundle, everything keeps going as it should. But, when I plug one of the leads back in that has been unplugged, sometimes the port goes into err-disable.
Is this normal?
My ether channel config is this, and is the same on both switches:
interface Port-channel1 description Link to Core 2 g1/0/11-12 switchport trunk encapsulation dot1q switchport trunk native vlan 5 switchport mode trunk
interface GigabitEthernet1/0/11 switchport trunk encapsulation dot1q switchport trunk native vlan 5 switchport mode trunk channel-group 1 mode on ! interface GigabitEthernet1/0/12 switchport trunk encapsulation dot1q switchport trunk native vlan 5 switchport mode trunk channel-group 1 mode on
Can anyone advise if this is me, or this is just normal, and maybe I have been talking my testing too far.
Regards
James
Try changing the mode te desirable.
