Port forwarding Issue.
Jan 30, 2007 5 Replies
Jump to replies (5)
Hi guys,
I need your help on port forwarding on CISCOrouter, I am new to configuring CISCO router, any way I did configuer my router, now I can internet and send and recieve mail, so this part is good. I did try to open these ports on the router; 25 ,22,443,4002 and I did forward these ports to one of my servers. but when I try to telnet any of these port I get no anserw at all or when I try to access my server (SBS 2003) with remote desktop (port 4002)no connection is made. I send you a copy of the router configuration,maybe some of you can see some mistake in it. Please let me know where is the problem. ( I did change the IP's for security reson).
myrouter#sh run Building configuration...
Current configuration : 4694 bytes ! version 12.4 no parser cache service nagle no service pad service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname mydomain ! boot-start-marker boot-end-marker ! enable secret 5 $1$QRTEUHN$Sb83SiFXpstr562NA/1iQZ/
950 ! aaa new-model ! ! aaa authentication login userauthen local aaa authorization network groupauthor local ! aaa session-id common ! resource policy ! no ip source-route ip cef ! ! ! ! ip tcp mss 1400 no ip domain lookup ip domain name mydomain.com ip inspect name myfw cuseeme timeout
3600 ip inspect name myfw http timeout
3600 ip inspect name myfw rcmd timeout
3600 ip inspect name myfw realaudio timeout
3600 ip inspect name myfw tftp timeout
30 ip inspect name myfw udp timeout 15 ip inspect name myfw tcp timeout
3600 ip inspect name myfw h323 timeout
3600 ! ! ! username johndo secret 5 $1$LJB.$ty/ MZ6auSm3khkhAIMGeTsF/ username test secret 5 $1$ub5k$b/ nmlDv4eMdRpKertyueEDL1 ! ! ! crypto isakmp policy 3 encr 3des authentication pre-share group 2 ! crypto isakmp policy 10 authentication pre-share group 2 crypto isakmp keepalive 10 ! crypto isakmp client configuration group groepje1 key 427sieb1 pool ippool ! ! crypto ipsec transform-set transset1 esp-3des esp-md5- hmac ! crypto dynamic-map dynmap 10 set transform-set transset1 ! ! crypto map crypmap1 client authentication list userauthen crypto map crypmap1 isakmp authorization list groupauthor crypto map crypmap1 client configuration address respond crypto map crypmap1 20 ipsec-isakmp dynamic dynmap ! ! ! ! interface BRI0 no ip address encapsulation hdlc shutdown ! interface ATM0 no ip address no ip route-cache cef no ip route-cache no ip mroute-cache no atm ilmi-keepalive pvc 0 8/48 encapsulation aal5mux ppp dialer dialer pool-member 1 ! dsl operating-mode auto ! interface FastEthernet0 ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! interface Vlan1 ip address 10.0.0.190
255.255.255.0 ip access-group 102 in ip nat insi ip inspect myfw in ip virtual-reassembly no ip route-cache cef no ip route-cache no ip mroute-cache hold-queue 100 out ! interface Dialer1 ip address negotiated ip access-group 113 in ip nat outside ip virtual-reassembly encapsulation ppp dialer pool 1 dialer-group 1 ppp authentication pap callin ppp pap sent-username snipped-for-privacy@xs4all.net password 7
66141601034200555953 crypto map crypmap1 ! ip local pool ippool 192.168.10.100
192.168.10.110 ip route 0.0.0.0 0.0.0.0 Dialer1 permanent ! ! no ip http server no ip http secure-server ip nat inside source static tcp 10.0.0.56 7 interface Dialer1
7 ip nat inside source static udp 10.0.0.56 7 interface Dialer1
7 ip nat inside source route-map nonat interface Dialer1 overload ip nat inside source static tcp 10.0.0.190 22 interface Dialer1
22 ip nat inside source static tcp 10.0.0.180 25 interface Dialer1
25 ip nat inside source static tcp 10.0.0.180 443 interface Dialer1
443 ip nat inside source static tcp 10.0.0.180 110 interface Dialer1
110 ip nat inside source static tcp 10.0.0.180 4002 interface Dialer1
4002 ! access-list 23 permit 82.66.199.22 access-list 23 permit 212.222.20.0
0.0.0.255 access-list 23 permit 10.0.0.0
0.0.0.255 access-list 102 permit ip 10.0.0.0 0.0.0.255 any access-list 102 permit ip 192.168.10.0 0.0.0.255 any access-list 102 permit esp any any access-list 105 deny ip 10.0.0.0 0.0.0.255 192.168.10.0
0.0.0.255 access-list 105 permit ip 10.0.0.0 0.0.0.255 any access-list 112 permit tcp any any eq smtp access-list 112 permit tcp any any eq 443 access-list 112 permit tcp any any eq pop3 access-list 112 permit tcp any any eq
4002 access-list 112 permit ip host 82.62.160.105 any access-list 112 deny ip any any access-list 113 permit ip 192.168.10.0 0.0.0.255 any access-list 113 permit esp any any access-list 113 permit udp any any eq isakmp access-list 113 permit tcp host 82.66.199.22 any eq 22 access-list 113 permit tcp 213.222.20.224 0.0.0.7 any eq 22 access-list 113 permit tcp host 193.172.44.45 eq tftp-data any access-list 113 permit tcp host 194.151.107.40 eq tftp-data any access-list 113 permit tcp host 194.151.107.44 eq tftp-data any access-list 113 permit icmp any any access-list 113 permit tcp any any eq echo access-list 113 permit udp any any eq echo access-list 113 deny ip any any access-list 115 permit ip any any access-list 115 permit esp any any dialer-list 1 protocol ip permit ! ! ! route-map nonat permit 10 match ip address 105 ! ! control-plane ! ! line con 0 --More--
You may want to investigate the Router Port Forward Wizard:
Sincerely,
Brad Reese Cisco Resumes
Although you have setup the NAT, I'd have thought you need to still allow the traffic through the firewall acl:
access-list 113 permit tcp any any eq 22 access-list 113 permit tcp any any eq 25 access-list 113 permit tcp any any eq 443 access-list 113 permit tcp any any eq 4002
Obviously, you might want to change the source addresses to be a bit more limited, or you might want to consider changing the ports rather than leave the defaults exposed to all....
Also, as you're using a numbered acl, I think you'll have to remove it & re-apply it as you can't delete/insert entries as you can with a named acl.
Regards,
Al
hi Al,
thanks for reply,
I did create a sepreated access list, access list 112: access-list 112 permit tcp any any eq 443 access-list 112 permit tcp any any eq pop3 access-list 112 permit tcp any any eq
do you think I should add this ports under access-list 113? or do I have to add extra line to access 112?eg
thanks again.
You will have to add the exceptions to whatever list you have applied to your outside interface, which is currently 113, e.g:
! Existing lines access-list 113 permit ip 192.168.10.0 0.0.0.255 any access-list 113 permit esp any any access-list 113 permit udp any any eq isakmp access-list 113 permit tcp host 82.66.199.22 any eq 22 access-list 113 permit tcp 213.222.20.224 0.0.0.7 any eq 22 access-list 113 permit tcp host 193.172.44.45 eq tftp-data any access-list 113 permit tcp host 194.151.107.40 eq tftp-data any access-list 113 permit tcp host 194.151.107.44 eq tftp-data any access-list 113 permit icmp any any access-list 113 permit tcp any any eq echo access-list 113 permit udp any any eq echo ! New lines access-list 113 permit tcp any any eq 22 access-list 113 permit tcp any any eq 25 access-list 113 permit tcp any any eq 443 access-list 113 permit tcp any any eq 4002 ! Deny any - does not do anything particularly as you're not logging matches & there's the implicit deny at the end anyway access-list 113 deny ip any any ! interface Dialer1 ip access-group 113 in !
As far as I can see, the ACL 112 is not applied & could eb removed.
HTH,
Al
