Catalyst 4507R "Command rejected: Not a convertible port."
Jan 27, 2005 2 Replies
Dear All,
We have a new trouble configuring L3 interfaces on cisco Catalyst
4507R.
When I do try configure a routed physical interface for L3 capabilities with the usual 'no switchport' command the next error (This error is not published on CCO accesing w/ Custumer level password neither I can get info about it googling): "Command rejected: Not a convertible port."
BACKGROUND
This is the way that I try configure the L3 physical interface:
---- SANQUINTIN#conf t Enter configuration commands, one per line. End with CNTL/Z. SANQUINTIN(config)#int gi4/24 SANQUINTIN(config-if)#no swit SANQUINTIN(config-if)#no switchport Command rejected: Not a convertible port.
I have active 'ip routing'
When I do 'sh ip int brief' The IP interface is present:
---- SANQUINTIN#sh ip int brief ... Interface IP-Address OK? Method Status Protocol GigabitEthernet4/24 unassigned YES unset down down
Interesting topic. Today i'm grappling w/ a 4507R w/ 12.2-25 i9s cod (basic L3), trying to do rpr+ ...when I try and configure rpr+
config
redundanc rpr invalid input detected at " ^ " marke
It would SEEM this guy doesn't want to DO rpr
Am I missing something
regards
Eric Lech
configure: (config)#redundancy (config-red)# mode rpr
