ISDN PRI dial in problems
Jan 24, 2006 2 Replies
Hello all, I have been trying to configure a Cisco 3745 as an access server with a PRI module for ISDN dial in. The problem is that the incoming call does not last more than 7 - 8 secs.I am including snippets of the config as well as some debug output. I'd be grateful if anyone can help
- I just cant figure out the error messages.
Thanks in advance, Shireen
Config _____________
isdn switch-type primary-qsig ! ! controller E1 2/0 framing NO-CRC4 ! controller E1 2/1 pri-group timeslots 1-31 ! interface Serial2/1:15 no ip address encapsulation ppp dialer pool-member 2 isdn switch-type primary-qsig isdn incoming-voice data isdn bchan-number-order ascending no fair-queue ! interface Dialer5 ip unnumbered loopback0 encapsulation ppp dialer pool 2 dialer-group 5 no peer default ip address ! dialer-list 5 protocol ip permit ________________________________
Mar 26 02:58:59.770: ISDN Se2/1:15 Q921: User RX
I would start with:
deb ppp auth deb ppp neg
Since the length of call seems to indicate problems there.
I also googled for qsig event 0x4a and it seems like that might indicate a far end disconnect. It can be instructive to get the same debugs from the far end. Make sure you have ntp configured on your routers so you can match times in the logs.
HTH,
Jeff
The debug below is telling you that PPP authentication failed
Without seeing the rest of your config I can only guess that you have not configured the authentication method for dialin.
Scott
