Broadcast forwarding to ISDN PRI
Dec 09, 2005 0 Replies
We use a Cisco 2621 and a NM-2CE1B (double ISDN PRI). 60 customers can dial in, each using one B-channel.
Is it possible to forward broadcast packets from the ethernet interface to all the B-channels, without using one 'ip helper-address' statement per B-channel. Altough this works, it makes to router unusable slow.
TIA, Marcel.
