Isdn BRI problem
Mar 05, 2007 1 Replies
Hi, we have a cisco 2811 router and 8 ipphones pluged behind.
We need to dial out by BRI connexions (we have a VIC2-BRI connected)
This VIC2 is directely connected to 2 t=E9l=E9phony op=E9rator (T0).
One BRI is functionnaly but when we want to use the second (4 lines) its not working (line busy after 2 lines).
here is my runnin-config
! version 12.4 service config no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone service timestamps log datetime msec localtime show-timezone service password-encryption service sequence-numbers ! hostname ciscovoip ! boot-start-marker boot-end-marker ! security authentication failure rate 10 log security passwords min-length 6 logging buffered 4096 debugging logging console critical enable secret 5 $1$7DZK$ZX.xf16B5hmZsCXIdpL.21 enable password 7 15311958077E3F2B0968 ! aaa new-model ! ! aaa authentication login local_auth local ! aaa session-id common ! resource policy ! network-clock-participate wic 0 no ip gratuitous-arps ip tcp synwait-time 10 ! ! ip cef ip dhcp use vrf connected ip dhcp excluded-address 192.142.66.1 192.142.66.9 ip dhcp excluded-address 192.142.66.31 192.142.66.254 ! ip dhcp pool dhcpvlan2 network 192.142.66.0 255.255.255.0 default-router 192.142.66.1 option 150 ip 192.142.65.253 lease infinite ! ! no ip bootp server ! isdn switch-type basic-net3 ! voice-card 0 no dspfarm ! ! ! voice service pots ! ! ! ! ! ! ! ! ! ! ! ! ! ! crypto pki trustpoint TP-self-signed-3414161613 enrollment selfsigned subject-name cn=3DIOS-Self-Signed-Certificate-3414161613 revocation-check none rsakeypair TP-self-signed-3414161613 ! ! crypto pki certificate chain TP-self-signed-3414161613 certificate self-signed 01 30820241 308201AA A0030201 02020101 300D0609 2A864886 F70D0101
04050030 31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D
43657274 69666963 6174652D 33343134 31363136 3133301E 170D3037 30333035
31313534 34375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504
03132649 4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33
34313431 36313631 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030
81890281 8100D127 7443713A 7DECF4CA 6261C920 B9F62799 C778BB61 B73D8F8D ABFC8B14 5119AB11 5F4ED842 2075B7E3 54CAEAFC 7860D9A6 5D30A23D 9C834C9C
0F000BF3 2BC43F5F A75D8DFE D565EAA0 627FED7C AEB4A398 B71C3349 AF175685
63B93D5E 66E62F6B B7D91B7D 8CBCB2BD 67758655 A3A72B95 B0ED1295 BA3E0808
74B3F9BF F19F0203 010001A3 69306730 0F060355 1D130101 FF040530 030101FF
30140603 551D1104 0D300B82 09636973 636F766F 6970301F 0603551D 23041830
16801428 41DC8777 297ECE56 60BD0E69 61091FF6 025B5230 1D060355 1D0E0416
04142841 DC877729 7ECE5660 BD0E6961 091FF602 5B52300D 06092A86 4886F70D
01010405 00038181 00353773 3E9CE928 14F1D185 4100B806 47505B20 1E8C3ADE
3DAC2892 28EC4DB3 21E917F7 42EB6003 5C7126DE 1DB81435 A5EAE4AD F825235D
3A8A2D66 A88ADE67 E1BD179E 5FF8A27B 415E6B34 88DA6BF5 D3203FBE ADEEBF06
6DA988C1 05C0CE41 A5245339 795309C9 E78115C8 F88F797E 426B8E0C EE52E696
7852795C DA507977 3F quit username administrateur password 7 03035E06071B285D5B0C ! ! ! ! ! interface Null0 no ip unreachables ! interface FastEthernet0/0 description $ETH-LAN$$FW_INSIDE$ ip address 192.142.65.253 255.255.255.0 no ip redirects no ip unreachables no ip proxy-arp duplex half speed auto no cdp enable no mop enabled ! interface Service-Engine0/0 no ip address no ip redirects no ip unreachables no ip proxy-arp shutdown no cdp enable no mop enabled ! interface FastEthernet0/1 no ip address no ip redirects no ip unreachables no ip proxy-arp shutdown duplex auto speed auto no cdp enable no mop enabled ! interface BRI0/0/0 no ip address isdn switch-type basic-net3 isdn twait-disable isdn tei-negotiation first-call isdn point-to-point-setup isdn incoming-voice voice ! interface BRI0/0/1 no ip address isdn switch-type basic-net3 isdn twait-disable isdn tei-negotiation first-call isdn point-to-point-setup isdn incoming-voice voice ! interface ATM0/3/0 no ip address no ip redirects no ip unreachables no ip proxy-arp shutdown no atm ilmi-keepalive dsl operating-mode auto ! interface FastEthernet1/0 switchport access vlan 2 ! interface FastEthernet1/1 switchport access vlan 2 ! interface FastEthernet1/2 switchport access vlan 2 ! interface FastEthernet1/3 switchport access vlan 2 ! interface FastEthernet1/4 switchport access vlan 2 ! interface FastEthernet1/5 switchport access vlan 2 ! interface FastEthernet1/6 switchport access vlan 2 ! interface FastEthernet1/7 switchport access vlan 2 ! interface FastEthernet1/8 switchport access vlan 2 ! interface FastEthernet1/9 switchport access vlan 2 ! interface FastEthernet1/10 switchport access vlan 2 ! interface FastEthernet1/11 switchport access vlan 2 ! interface FastEthernet1/12 switchport access vlan 2 ! interface FastEthernet1/13 switchport access vlan 2 ! interface FastEthernet1/14 switchport access vlan 2 ! interface FastEthernet1/15 switchport access vlan 2 ! interface Vlan1 no ip address no ip redirects no ip unreachables no ip proxy-arp no mop enabled ! interface Vlan2 description $FW_INSIDE$ ip address 192.142.66.1 255.255.255.0 no ip redirects no ip unreachables no ip proxy-arp ! ip route 192.142.65.0 255.255.255.0 Vlan1 ip route 192.142.66.0 255.255.255.0 Vlan2 ! no ip http server ip http access-class 1 ip http secure-server ! logging trap debugging logging facility local2 access-list 1 remark HTTP Access-class list access-list 1 remark SDM_ACL Category=3D1 access-list 1 permit 192.142.66.0 0.0.0.255 access-list 1 permit 192.142.65.0 0.0.0.255 access-list 1 deny any access-list 100 permit udp any any eq bootpc access-list 101 remark VTY Access-class list access-list 101 remark SDM_ACL Category=3D1 access-list 101 permit ip 192.142.66.0 0.0.0.255 any access-list 101 permit ip 192.142.65.0 0.0.0.255 any access-list 101 deny ip any any access-list 101 remark VTY Access-class list access-list 101 remark SDM_ACL Category=3D1 access-list 101 remark VTY Access-class list access-list 101 remark SDM_ACL Category=3D1 dialer-list 1 protocol ip permit ! ! tftp-server flash:cnu41.2-7-6-26.sbn tftp-server flash:CVM41.2-0-2-26.sbn tftp-server flash:Jar41.2-9-2-26.sbn tftp-server flash:TERM41.7-0-3-0S.loads tftp-server flash:term41.default.loads tftp-server P0030702T023.bin tftp-server P0030702T023.loads tftp-server P0030702T023.sb2 tftp-server P0030702T023.sbn tftp-server system:/its tftp-server flash:ATA030201SCCP050429A.zup tftp-server startup-config ! control-plane ! ! ! voice-port 0/0/0 echo-cancel coverage 24 compand-type a-law cptone FR bearer-cap Speech ! voice-port 0/0/1 echo-cancel coverage 24 compand-type a-law cptone FR bearer-cap Speech ! ccm-manager sccp local Vlan2 ! ! ! dial-peer cor custom ! ! ! dial-peer voice 1 pots destination-pattern .T progress_ind setup enable 3 progress_ind progress enable 8 progress_ind connect enable 8 direct-inward-dial port 0/0/0 forward-digits all ! dial-peer voice 2 pots destination-pattern .T progress_ind setup enable 3 progress_ind progress enable 8 progress_ind connect enable 8 direct-inward-dial port 0/0/1 forward-digits all ! ! num-exp 553074306 703 ! telephony-service load ATA ATA030201SCCP050429A.zup load 7941 P0030702T023 max-ephones 15 max-dn 15 ip source-address 192.142.65.253 port 2000 auto assign 1 to 15 user-locale FR user-locale 1 FR user-locale 2 FR user-locale 3 FR user-locale 4 FR network-locale FR network-locale 1 FR network-locale 2 FR network-locale 3 FR network-locale 4 FR voicemail 800 max-conferences 15 gain -6 transfer-system full-consult create cnf-files version-stamp Jan 01 2002 00:00:00 ! ! ephone-dn-template 1 ! ! ephone-dn 1 dual-line number 700 name JLL preference 1 call-forward busy 702 call-forward noan 702 timeout 18 no huntstop ! ! ephone-dn 2 dual-line number 701 name DC call-forward busy 700 call-forward noan 700 timeout 18 ! ! ephone-dn 3 dual-line number 702 name DB call-forward busy 709 call-forward noan 709 timeout 18 ! ! ephone-dn 4 dual-line ring external primary number 703 name CC call-forward busy 713 call-forward noan 713 timeout 18 ! ! ephone-dn 5 dual-line number 710 name SP call-forward busy 701 call-forward noan 701 timeout 18 ! ! ephone-dn 6 dual-line number 709 name ASS call-forward busy 707 call-forward noan 707 timeout 18 ! ! ephone-dn 7 dual-line number 713 name HD call-forward busy 701 call-forward noan 701 timeout 18 ! ! ephone-dn 8 dual-line number 708 name KK call-forward busy 710 call-forward noan 710 timeout 18 ! ! ephone-dn 9 number 715 name FAX ! ! ephone 1 no multicast-moh mac-address 0017.95BF.A63F type 7941 button 1:1 ! ! ! ephone 2 no multicast-moh mac-address 0017.9518.097D type 7941 button 1:2 ! ! ! ephone 3 no multicast-moh mac-address 0017.95B0.F7B1 type 7941 button 1:3 ! ! ! ephone 4 no multicast-moh mac-address 0017.95BF.A6F8 type 7941 button 1:4 ! ! ! ephone 5 no multicast-moh mac-address 0017.957D.FF3B type 7941 button 1:5 ! ! ! ephone 6 no multicast-moh mac-address 0017.95B0.F2FD type 7941 button 1:6 ! ! ! ephone 7 no multicast-moh mac-address 0017.95B0.E6FC type 7941 button 1:7 8:9 ! ! ! ephone 8 no multicast-moh mac-address 0017.95B0.F68D type 7941 button 1:8 ! ! ! ephone 9 mac-address 17E0.553A.5A01 type ata button 1:9 ! ! ! ephone 10 mac-address 0017.E055.3A5A type ata ! ! ephone-hunt 1 sequential ! ! banner login ienvenu a gematique  banner motd ienvenu gematique  ! line con 0 login authentication local_auth transport output telnet line aux 0 login authentication local_auth transport output telnet line 194 exec-timeout 15 0 login authentication local_auth no activation-character no exec transport preferred none transport input all transport output pad telnet rlogin lapb-ta mop udptn v120 ssh line vty 0 4 access-class 101 in password 7 050C0302205847180C00 login authentication local_auth transport input telnet ! scheduler allocate 20000 1000 no process cpu extended no process cpu autoprofile hog ! end
THANKS IN ADVANCE !!!
give us more info about ISDN status? sh isdn status
