ISDN backup for leaseline - need help
Oct 26, 2005 2 Replies
I have two sites connected with a leaseline. I'm trying to setup a isdn line for backup but it doesn't work. Below is two routers config :
Router A
interface Serial0 ip address 192.168.245.1 255.255.255.252 ! interface Dialer0 ip address 192.168.246.1 255.255.255.252 encapsulation ppp no ip route-cache dialer pool 1 dialer remote-name jwtmumb dialer idle-timeout 300 dialer string 23889760 dialer-group 1 ppp authentication chap
ip classless ip route 0.0.0.0 0.0.0.0 Serial0 ip route 0.0.0.0 0.0.0.0 Dialer0 180
Router B
interface Serial0/0 ip address 192.168.245.2 255.255.255.252
interface BRI1/0 no ip address encapsulation ppp dialer pool-member 1 isdn switch-type basic-net3 no cdp enable ppp authentication chap
interface Dialer0 ip address 192.168.246.2 255.255.255.252 encapsulation ppp dialer pool 1 dialer remote-name fortipan dialer-group 1 no cdp enable ppp authentication chap
ip route 0.0.0.0 0.0.0.0 s0/0 ip route 0.0.0.0 0.0.0.0 Dialer0 180
- I did some test, unplug the primary connection on router A, but the isdn line did not kick in. Can any expert help me to check if any missign in my configuration ?
Many thanks :-)
You havent configure the dialer-list command to specify interesting traffic to dial the ISDN eg below
dialer-list 1 protocol ip permit
Hello,
in addition to what Elvis said, also make sure that you have the remote username adn password configured on your local routers:
Router A
username jwtmumb password xxxx
Router B
username fortipan password xxxx
Make sure the passwords match. In addition, you might want to specify the command 'backup interface dialer0' on your serial interfaces:
Router A
interface Serial0 backup interface Dialer0
Router B
That way, the ISDN only kicks in when your serial interface line protocol goes down...
Regards,
Naz
