dialer watch problem
Mar 17, 2007 2 Replies
am usimg FR links and ISDN as backup using dialer watches. What I've noticed that if router is rebooted and primary link is down, ISDN is never dialed. Like there is a problem with initial state of watched route. Is this possible?
Thanks!
! ! interface BRI0/0/0 no ip address encapsulation ppp no ip route-cache cef no ip route-cache no ip mroute-cache load-interval 30 dialer pool-member 1 isdn switch-type basic-net3 isdn point-to-point-setup no keepalive no cdp enable ppp multilink ! interface Dialer0 ip address 172.31.58.6 255.255.255.252 encapsulation ppp no ip route-cache cef no ip route-cache ip tcp header-compression iphc-format no ip mroute-cache delay 50000 dialer pool 1 dialer remote-name xxxxxxxx dialer order last-successful dialer idle-timeout 30 dialer wait-for-line-protocol 15 dialer string 111111111 dialer string 222222222 dialer load-threshold 1 either dialer watch-group 5 dialer-group 1 no cdp enable ppp authentication chap ppp multilink ppp multilink fragment delay 10 ppp multilink interleave max-reserved-bandwidth 95 service-policy output POSL_OUT ip rtp header-compression iphc-format ! !
dialer watch-list 5 ip 172.30.30.0 255.255.255.252 dialer-list 1 protocol ip deny ! ! !
Sounds familiar. The route had to be up before it could go down and trigger the dialer watch. Might even have been a change in IOS to make it work differently. Can't remember right now.
dialer watch-list 5 delay route-check initial 5
