IS IPSEC FEATURE REQUIRED IN THE CUSTOMER EDGE ROUTER ?
Oct 23, 2005 4 Replies
stephen
it depends. MPLS doesnt need IPsec or any other tunnelling to work, and the edge router only needs simple IP forwarding - all that label stuff happens in the network core, on the PE and P routers. if this is a "private" MPLS service, and you dont consider the risk of the…
Hi folks,
In the context of the IPVPN (MPLS), is the customer edge router has to support IPSEC?
Thanks, ConceptZone
it depends.
if this is a "private" MPLS service, and you dont consider the risk of the carrier tapping the traffic a big problem then no security is needed.
The Q you didnt ask is whether you should use encryption - you dont have to but you can if you want (the same answer as for a VPN across the Internet really).
Thank you so much really, you gave me a great answer, just one thing more raised up in my mine
what about the voice cpmression across MPLS ?
thanks again
ConceptZone
thanks again
ConceptZone
stephen wrote:
voice compression in IP? - its just IP......
headers (for voice specifically because it is lots of small packets) - see below
can you do data (not just voice) compression across a serial link? - yes - but most carriers (at least here in UK) dont because: they sell bandwidth for a living the hit on the aggregation / PE router for processing is painful.
Also data compression gives a "variable return" - in particular the more pre processing (compression, encryption), the less the improvement in thruput. Try writing that into an SLA.......
