IPSec
Oct 04, 2005 3 Replies
Jump to replies (3)
How to create vpn ipsec tunnel from another site with dynamic ip?
IPSec open original image
Hi All
I have set up a tunnel between 2 IOS Routers A and B (1760 and 1841).
A has a single FastEth interface, and B 2 of them, FE0/0 with the crypto map, and FE0/1 connected to my LAN.
While logged on A, I ping from A router the LAN interface of B router, the ISAKMP/IPSec negociation establishes the tunnel.
With sh crypto ipsec sa I see that the datagrams (pings) are encrypted on A #pkts encaps: 4, #pkts encrypt: 4, #pkts digest 4
but on B router, the sh crypto ipsec sa shows no data decrypted #pkts decaps: 0, #pkts decrypt: 0, #pkts verify 0
¿ Why isn't B router showing that he is receiveing the datagrams sent through the tunnel ?
Regards
Jaime
In article , TERRA wrote: :I have set up a tunnel between 2 IOS Routers A and B (1760 and 1841).
;A has a single FastEth interface, and B 2 of them, FE0/0 with the crypto ;map, and FE0/1 connected to my LAN.
:While logged on A, I ping from A router the LAN interface of B router, the :ISAKMP/IPSec negociation establishes the tunnel.
:With sh crypto ipsec sa I see that the datagrams (pings) are encrypted on A :#pkts encaps: 4, #pkts encrypt: 4, #pkts digest 4
:but on B router, the sh crypto ipsec sa shows no data decrypted : #pkts decaps: 0, #pkts decrypt: 0, #pkts verify 0
:¿ Why isn't B router showing that he is receiveing the datagrams sent :through the tunnel ?
As a guess: you might have a mismatch in the crypto ACLs used to define the tunnels. If you aren't careful, you can end up in situations where B expects the traffic to have been on a different SA than A thinks.
This can occur especially if you have overlapping ranges, such as "all of A to host B1" and "host A2 to all of B" -- e.g., which SA do you use to communicate from host A2 to B1 ?
