IP telephone and IBM desktops
Sep 09, 2005 1 Replies
Has anyone had issues connecting IBM desktops to the network through a Cisco 7960 IP phone. IBM laptop works fine.
It has been suggested that it might be a BIOS version or Driver version issue.
It might be. I'd like to see if others have had similar issues.
If the PC works when plugged into a switchport, it should work plugged into a phone... Unless.
You have disabled the 7960 switchport.
You also might have buggy code on the 7960, upgrade it to 7.2.2
Jonathan
