HowTo select the certificate for web-based authentication (HTTPS-cert)
Dec 06, 2006 2 Replies
HowTo select the certificate for web-based authentication (HTTPS-cert) open original image
Hi all, can someone tell me how i can select / change the certificate for the https-Authentication with pix / FWSM
thanks
Hi all, i cant use asdm. I have nested service-groups that asdm cant handle. I use the CSM. I have installed the ca certificate and one device zertificate. I can see this at running config and after wr mem at the startup-config. the auth-website use the old selfsigned cert. after reboot the auth-website use one new selfsigned cert not my installed one. with show crypto ca cert i can see the 2 certs. How can i select my own certificate for web-auth? The user should not see the "untrusted" certificate for web-auth.
DK
"Brian V" schrieb im Newsbeitrag news:WNGdnQxOEKrVp-rYnZ2dnUVZ snipped-for-privacy@comcast.com...
