Hello:
Currently I administer my VPN 3000 via Firefiox HTTP://
I want to make this HTTPS://
Is it possible to install a cert just for remote administration on this device?
Thanks
You should enable SSL/HTTPS for administration: Configuration -> Tunneling and Security -> SSL -> HTTPS ...and disable HTTP access: Configuration -> System -> Management Protocols -> HTTP Make sure you have SSL Certificate installed, and if not, generate and import itβ¦
Read the full replyHello:
Thanks
Make sure you have SSL Certificate installed, and if not, generate and import it:
Administration -> Certificate Management -> Installation -> Install SSL Certificate
Good luck,
Mike CCNP, CCDP, CCSP, Cisco Voice, MCSE W2K, MCSE+I, Security+, etc. CCIE R&S (in progress), CCIE Voice (in progress)
------ Headset Adapters for Cisco IP Phones
